Ga door naar hoofdinhoud
Disassembling Coby Kyros MID9742 Outer Casing
Wat je nodig hebt
  1. Disassembling Coby Kyros MID9742 Outer Casing, Outer Casing: stap 1, afbeelding 1 van 1
    • Use a spudger to remove the four rubber screw covers from the four back corners of the tablet.
  2. Disassembling Coby Kyros MID9742 Outer Casing: stap 2, afbeelding 1 van 1
    • Place the PH00 screwdriver and use it to remove the four 0.5 cm screws from each corner of the tablet.
  3. Disassembling Coby Kyros MID9742 Outer Casing: stap 3, afbeelding 1 van 1
    • Place a metal spudger tool in between the front and back panels of the tablet and begin to pry the base from the front panel by moving the metal tool around the perimeter of the tablet.
    • Note that clicking noises will be heard during this process, the panels are assembled well so it may take some force to separate the two panels.
    • Use caution while prying, do not stick the metal spudger in too far as it may damage internal components
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Ian Swett
597 Reputatie
5 handleidingen geschreven
Colorado Springs, Team 5-3, Panko Spring 2015 Lid van Colorado Springs, Team 5-3, Panko Spring 2015
UCCS-PANKO-S15S5G3
3 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 11
Altijd: 478
