Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Inleiding
The logic board is the brains behind the camera and should be handled delicately.
Onderdelen
Geen onderdelen opgegeven.
  1. Remove the 2 screws (2.41 mm long) on the side of the camera next to the LCD screen. Remove the 2 screws (4.08 mm) on the other side.  One is located under the rubber USB flap. Remove the last screw (2.59 mm) located on the bottom of the camera.
    • Remove the 2 screws (2.41 mm long) on the side of the camera next to the LCD screen.
    • Remove the 2 screws (4.08 mm) on the other side. One is located under the rubber USB flap.
    • Remove the last screw (2.59 mm) located on the bottom of the camera.
    • Slowly pull the back cover of the camera.
  2. Remove the screw (2.59 mm) from the bottom of the camera. Remove the screw (4.08 mm) from the menu button side of the camera. Note: the 2 screws on the other side of the camera were already removed when taking off the back cover.
    • Remove the screw (2.59 mm) from the bottom of the camera.
    • Remove the screw (4.08 mm) from the menu button side of the camera.
    • Note: the 2 screws on the other side of the camera were already removed when taking off the back cover.
  3. Unplug the green and white plugs connecting the top panel to the top of the logic board. Dislodge the tab above the lens.
    • Unplug the green and white plugs connecting the top panel to the top of the logic board.
    • Dislodge the tab above the lens.
    • Dislodge the back tab.
  4. Remove 2 screws(1.75mm) using a screwdriver.
    • Remove 2 screws(1.75mm) using a screwdriver.
    • Detach 3 ribbons by pulling up on them. All are on the front of the camera.
  5. Remove the newly exposed screw(1.75mm) with screwdriver. Unhinge the black tab to slide out the ribbon.
    • Remove the newly exposed screw(1.75mm) with screwdriver.
    • Unhinge the black tab to slide out the ribbon.
    • The only thing keeping logic board in place is a black nub. Lift the logic board from that corner with increasing force until it pops out.
Conclusie
Juan Miguel
101 Reputatie
1 Handleiding geschreven
Cal Poly, Team 13-3, Forte Winter 2011 Lid van Cal Poly, Team 13-3, Forte Winter 2011
CPSU-FORTE-W11S13G3
5 Leden
8 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 6
Altijd: 1,794
