Ga door naar hoofdinhoud
Canon Powershot SD880 LCD Display Replacement
Wat je nodig hebt
  1. Canon Powershot SD880 LCD Display Replacement, Back Cover: stap 1, afbeelding 1 van 3 Canon Powershot SD880 LCD Display Replacement, Back Cover: stap 1, afbeelding 2 van 3 Canon Powershot SD880 LCD Display Replacement, Back Cover: stap 1, afbeelding 3 van 3
    • Remove the two 2.4 mm screws on the side of the camera that are next to the LCD screen using a Phillips #00 screwdriver.
    • Remove the two 4.1 mm screws on the other side using a Phillips #00 screwdriver.
    • One screw will be located under the rubber USB flap.
    • Remove the single 2.6 mm screw from the bottom of the camera using a Phillips #00 screwdriver.
    • Slowly pull the back cover off of the camera.
  2. Canon Powershot SD880 LCD Display Replacement, LCD Display: stap 2, afbeelding 1 van 3 Canon Powershot SD880 LCD Display Replacement, LCD Display: stap 2, afbeelding 2 van 3 Canon Powershot SD880 LCD Display Replacement, LCD Display: stap 2, afbeelding 3 van 3
    • Remove the two 2.9 mm screws at the top-right corner and bottom-left corner of the LCD screen using a Phillips #0 screwdriver.
    • Disconnect the ribbons that connect the screen to the camera.
    • Lift the screen off.
Conclusie
Ben Tupas
317 Reputatie
3 handleidingen geschreven
Cal Poly, Team 13-3, Forte Winter 2011 Lid van Cal Poly, Team 13-3, Forte Winter 2011
CPSU-FORTE-W11S13G3
5 Leden
8 handleidingen geschreven
Één opmerking
Hm. "Disconnect the ribbons" resulted in a torn ribbon, and so a dead camera, I think. This also doesn't say how to take the LCD screen out of its frame. Alas.
Maelduin - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 18
Altijd: 2,320
