Ga door naar hoofdinhoud
Disassembling Canon PowerShot SD850 IS Case Removal
Wat je nodig hebt
  1. Disassembling Canon PowerShot SD850 IS Case Removal, Battery: stap 1, afbeelding 1 van 3 Disassembling Canon PowerShot SD850 IS Case Removal, Battery: stap 1, afbeelding 2 van 3 Disassembling Canon PowerShot SD850 IS Case Removal, Battery: stap 1, afbeelding 3 van 3
    • Slide the light grey tab toward the edge of the camera using your fingernail.
    • Pull the light grey tab up to open the door.
    • These photos do not show the camera’s memory card or battery, which should be visible inside.
  2. Disassembling Canon PowerShot SD850 IS Case Removal: stap 2, afbeelding 1 van 2 Disassembling Canon PowerShot SD850 IS Case Removal: stap 2, afbeelding 2 van 2
    • Slide the small brown tab toward the edge of the camera using your fingernail.
    • Let go of the brown tab when the battery pops up.
    • Grab battery and pull straight up to remove from holder.
    • When inserting the battery, orient it so that the terminals connect.
  3. Disassembling Canon PowerShot SD850 IS Case Removal, Case: stap 3, afbeelding 1 van 2 Disassembling Canon PowerShot SD850 IS Case Removal, Case: stap 3, afbeelding 2 van 2
    • Remove the following 4 screws:
    • Two 2.8 mm Phillips #00 at the bottom of the camera.
    • Two 2.75 mm Phillips #00 on the opposite side of the wrist strap.
  4. Disassembling Canon PowerShot SD850 IS Case Removal: stap 4, afbeelding 1 van 3 Disassembling Canon PowerShot SD850 IS Case Removal: stap 4, afbeelding 2 van 3 Disassembling Canon PowerShot SD850 IS Case Removal: stap 4, afbeelding 3 van 3
    • Open the A/V OUT DIGITAL flap on the side of the wrist strap.
    • Remove the 2.75 mm Phillips #00 under the A/V OUT DIGITAL flap on the side of the wrist strap.
  5. Disassembling Canon PowerShot SD850 IS Case Removal: stap 5, afbeelding 1 van 2 Disassembling Canon PowerShot SD850 IS Case Removal: stap 5, afbeelding 2 van 2
    • On the bottom of the camera, use your fingernail to slide the light gray tab towards the edge of the camera.
    • Slide light gray door and pull up to open the door.
    • Remove the 8.35 mm Phillips #00 next to the brown tab that holds the battery.
  6. Disassembling Canon PowerShot SD850 IS Case Removal: stap 6, afbeelding 1 van 2 Disassembling Canon PowerShot SD850 IS Case Removal: stap 6, afbeelding 2 van 2
    • Gently pull the front cover straight out from the camera. This will expose the wiring on the front of the camera.
  7. Disassembling Canon PowerShot SD850 IS Case Removal: stap 7, afbeelding 1 van 1
    • Remove the 2.75 mm Phillips #00 next to A/V OUT DIGITAL.
  8. Disassembling Canon PowerShot SD850 IS Case Removal: stap 8, afbeelding 1 van 1
    • Slide the back casing (with the screen protector) off to reveal the LCD and back wiring.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Peter Tran
225 Reputatie
6 handleidingen geschreven
Cal Poly, Team 20-7, Maness Fall 2010 Lid van Cal Poly, Team 20-7, Maness Fall 2010
CPSU-MANESS-F10S20G7
6 Leden
7 handleidingen geschreven
Één opmerking
Had to exchange a battery/SD card cover on an Ixus970IS. This guide very helpful showing the way due to similar layout of the Ixus and the PS850IS! Thanx a lot! :-)
KBK Copenhagen DK
Keld Baden-Kristensen - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 25
Altijd: 4,281
