Ga door naar hoofdinhoud
Inleiding
Removing the front cover allows access to the flash assembly.
Onderdelen
Geen onderdelen opgegeven.
  1. Remove one 2.25mm screw on the bottom.
    • Remove one 2.25mm screw on the bottom.
  2. Remove two 2.25mm screws on the right side looking from the front.
    • Remove two 2.25mm screws on the right side looking from the front.
  3. Remove one 4.7mm screw on the side with the AV output.
    • Remove one 4.7mm screw on the side with the AV output.
  4. Pull off the back cover.
    • Pull off the back cover.
    • The back cover tends to stick in the top corner (near the mode dial) due to a metal clip. Jiggle the cover side to side as you pull it out.
  5. Remove the 3.9mm screw in the AV housing on the left side from the front of the camera.
    • Remove the 3.9mm screw in the AV housing on the left side from the front of the camera.
  6. Remove one 2.25mm screw on the bottom of the camera.
    • Remove one 2.25mm screw on the bottom of the camera.
  7. Pull off the front cover.
    • Pull off the front cover.
Conclusie
Jeremy Rabaino
135 Reputatie
6 handleidingen geschreven
Cal Poly, Team 20-9, Maness Fall 2010 Lid van Cal Poly, Team 20-9, Maness Fall 2010
CPSU-MANESS-F10S20G9
5 Leden
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 0
Afgelopen 30 Dagen: 0
Altijd: 2,293
