Ga door naar hoofdinhoud
Disassembling Canon PowerShot SD1100 IS LCD screen
Wat je nodig hebt
  1. Disassembling Canon PowerShot SD1100 IS LCD screen, Front and Rear Cover: stap 1, afbeelding 1 van 2 Disassembling Canon PowerShot SD1100 IS LCD screen, Front and Rear Cover: stap 1, afbeelding 2 van 2
    • Remove wrist strap and battery.
  2. Disassembling Canon PowerShot SD1100 IS LCD screen: stap 2, afbeelding 1 van 3 Disassembling Canon PowerShot SD1100 IS LCD screen: stap 2, afbeelding 2 van 3 Disassembling Canon PowerShot SD1100 IS LCD screen: stap 2, afbeelding 3 van 3
    • Remove 2 screws from each side of the camera (4 total, 0.102 in).
    • Remove 2 screws from the bottom on the camera (0.138 in).
    • Do not mix the 4 side screws with the 2 bottoms ones; they are different sizes.
  3. Disassembling Canon PowerShot SD1100 IS LCD screen: stap 3, afbeelding 1 van 3 Disassembling Canon PowerShot SD1100 IS LCD screen: stap 3, afbeelding 2 van 3 Disassembling Canon PowerShot SD1100 IS LCD screen: stap 3, afbeelding 3 van 3
    • Gently pull off the front cover.
    • The plate on the side should come off.
    • Gently pull off the back cover.
  4. Disassembling Canon PowerShot SD1100 IS LCD screen: stap 4, afbeelding 1 van 1
    • The cases should now be removed.
  5. Disassembling Canon PowerShot SD1100 IS LCD screen, LCD screen: stap 5, afbeelding 1 van 2 Disassembling Canon PowerShot SD1100 IS LCD screen, LCD screen: stap 5, afbeelding 2 van 2
    • Remove the top-left screw above the LCD screen (0.100 in).
    • Remove the C-shaped plate from the side of the LCD screen.
  6. Disassembling Canon PowerShot SD1100 IS LCD screen: stap 6, afbeelding 1 van 2 Disassembling Canon PowerShot SD1100 IS LCD screen: stap 6, afbeelding 2 van 2
    • Remove the screw from the top-right of the LCD screen (0.098 in).
    • Remove the L-shaped bar from the right of the LCD screen.
  7. Disassembling Canon PowerShot SD1100 IS LCD screen: stap 7, afbeelding 1 van 2 Disassembling Canon PowerShot SD1100 IS LCD screen: stap 7, afbeelding 2 van 2
    • Use the spudger to remove the L-shaped bar from the left-side of the LCD screen.
  8. Disassembling Canon PowerShot SD1100 IS LCD screen: stap 8, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Koop
    • Use tweezers to remove the connector ribbon from the top-left corner above the LCD screen.
    • Be gentle. This ribbon should stay attached to the screen.
  9. Disassembling Canon PowerShot SD1100 IS LCD screen: stap 9, afbeelding 1 van 3 Disassembling Canon PowerShot SD1100 IS LCD screen: stap 9, afbeelding 2 van 3 Disassembling Canon PowerShot SD1100 IS LCD screen: stap 9, afbeelding 3 van 3
    • Use a spudger to lift the connector lock (black flap) at the end of the larger LCD connector ribbon on the front side of the camera.
    • Use the tweezers to lift this ribbon.
    • Use the tweezers to gently peel this ribbon from the one underneath it.
  10. Disassembling Canon PowerShot SD1100 IS LCD screen: stap 10, afbeelding 1 van 1
    • The LCD screen should now be removed.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Tyler Grossheim
1.470 Reputatie
6 handleidingen geschreven
Cal Poly, Team 3-32, Regan Winter 2011 Lid van Cal Poly, Team 3-32, Regan Winter 2011
CPSU-REGAN-W11S3G32
3 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 27
Altijd: 3,608
