Ga door naar hoofdinhoud
Disassembling Canon PowerShot S50 Outer Casing
Wat je nodig hebt
  1. Disassembling Canon PowerShot S50 Outer Casing, Battery: stap 1, afbeelding 1 van 2 Disassembling Canon PowerShot S50 Outer Casing, Battery: stap 1, afbeelding 2 van 2
    • Place camera LCD side up and press up on the battery door.
    • Let it swing open until you can see the battery inside.
  2. Disassembling Canon PowerShot S50 Outer Casing: stap 2, afbeelding 1 van 1
    • Press down on the orange plastic.
    • This will gently eject the battery from its compartment.
  3. Disassembling Canon PowerShot S50 Outer Casing: stap 3, afbeelding 1 van 2 Disassembling Canon PowerShot S50 Outer Casing: stap 3, afbeelding 2 van 2
    • Holding the edges, slide out the battery.
  4. Disassembling Canon PowerShot S50 Outer Casing, Front Panel/Battery Door: stap 4, afbeelding 1 van 1
    • Look at the camera from the side with the lanyard and 4 screws.
    • Remove the two 3.4 mm screws on the metallic colored part.
  5. Disassembling Canon PowerShot S50 Outer Casing: stap 5, afbeelding 1 van 1
    • Remove the 3mm screw on the top left.
    • NOTE: When reassembling, it is helpful to put the top screw back in before placing the front cover back on the camera.
    • Now remove the 5.3mm screw on the bottom.
  6. Disassembling Canon PowerShot S50 Outer Casing: stap 6, afbeelding 1 van 1
    • Place the camera LCD side down.
    • Remove the two 5.3mm screws by the battery door.
  7. Disassembling Canon PowerShot S50 Outer Casing: stap 7, afbeelding 1 van 1
    • Remove the four 3.4mm screws on the bottom of the camera around the tripod mount.
    • Make sure to keep these screws separate from the previous 5.3 mm screws.
  8. Disassembling Canon PowerShot S50 Outer Casing: stap 8, afbeelding 1 van 1
    • Stand the camera back up.
    • Remove the two 3.6mm screws on the side with the A/V Out port.
  9. Disassembling Canon PowerShot S50 Outer Casing: stap 9, afbeelding 1 van 1
    • Lift open the rubber flap covering the A/V Out port.
    • Remove the 3.4mm screw in the center.
    • During reassembly, put the A/V out rubber door on before replacing the front panel of the camera
  10. Disassembling Canon PowerShot S50 Outer Casing: stap 10, afbeelding 1 van 1
    • Use a spudger and gently open up the front panel of the camera.
    • A thin plastic ribbon will stay connected by a brown piece to front panel of the camera.
  11. Disassembling Canon PowerShot S50 Outer Casing: stap 11, afbeelding 1 van 1
    • There will be a brown plastic piece keeping the thin plastic ribbon in place.
    • Use the spudger to pull out the brown plastic piece attached to the orange plastic.
  12. Disassembling Canon PowerShot S50 Outer Casing: stap 12, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Koop
    • Use a pair of tweezers and remove the metal piece inside the camera.
  13. Disassembling Canon PowerShot S50 Outer Casing: stap 13, afbeelding 1 van 1
    • Remove the battery door
    • NOTE: Putting this back on requires aligning the spring on the back of the door with the hole on the camera
  14. Disassembling Canon PowerShot S50 Outer Casing, Outer Casing: stap 14, afbeelding 1 van 1
    • Using a spudger, gently separate the back panel from the rest of the camera and remove it.
Conclusie
Karim
24 Reputatie
3 handleidingen geschreven
Cal Poly, Team 7-34, Maness Spring 2012 Lid van Cal Poly, Team 7-34, Maness Spring 2012
CPSU-MANESS-S12S7G34
5 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 21
Altijd: 1,691
