Inleiding
This guide will show you how to disassemble the Canon PowerShot G16.
Wat je nodig hebt
Open the battery flap on the bottom of the camera by applying pressure and pushing in the direction of the arrow.
Remove your finger and allow the flap to pop open.
Remove the ring around the lens by simultaneously pressing the black button located at the bottom right of the ring and rotating the ring counterclockwise.
Reorient the camera so that you are looking at the back.
Unplug the button circuit board from the motherboard by unlocking the ZIF connector (gently lift the brown lock that keeps the cable in place).
Pull the connector downwards with the tweezers.
Unlock the ZIF connector for the large connector ribbon by lifting up on the brown flap with the plastic opening tool.
Gently pull the connector straight out of the housing with your fingers.
Remove the newly uncovered 2.8 mm screw from the right of the viewfinder using a Phillips #00 screwdriver.
Remove the 4.9 mm screw from top right of the metal casing on the back using a Phillips #00 screwdriver.
Remove the 4.3 mm screw from bottom right of the metal casing on the back using a Phillips #00 screwdriver.
Remove the newly uncovered screws from the right of the viewfinder using a Phillips #00 screwdriver. (Note, they're already removed on the picture)
Reorient the camera so that black lens cover is facing you with viewfinder on top.
Remove the four 5.3 mm screws around the lens using a Phillips #00 screwdriver.
Remove the 3.8 mm screw above the lens using a Phillips #00 screwdriver.
Remove the two 2.8 mm screws on the top of the lens assembly near the viewfinder using a Phillips #00 screwdriver.
7 andere personen hebben deze handleiding voltooid.
5 opmerkingen
Thank you SO MUCH. One of our company cameras, a PowerShot G15 had a dead display. A person on the Canonforum…
https://community.usa.canon.com/t5/Power...
…recommended disassembling the camera via iFixit instructions for the G16 (slightly different than the G15), unplugging the display, and plugging it back in again…WHICH WORKED. Did the whole thing in about 30 minutes. Awesome. Saved us a lot of money. Very grateful.
Hi,
Could you describe how to disassemble and assemble the lens curtain - th esix leaves and two springs that cover the lens when the lens is retracted into the camera? I’ve tried to assemble it, but end up with the mechanism only closing 2/3rd way. It opens fine. I want to replace my scratched lens with an unscratched one, but the new one is the one with the curtain problem. Thank you!
i have the same question...
