Inleiding
This guide will instruct the user on how to remove the front cover of the Canon A590 IS.
Gereedschap
Onderdelen
Geen onderdelen opgegeven.
The battery hatch is on the bottom of the camera.
While the switch is pushed forward, pull the cover away from the camera.
This camera requires AA batteries. To remove batteries, simply allow them to fall out of the camera.
The clock battery cover is shown here in the purple circle. Use a fingernail to lift the battery out of the camera.
When replacing the AA batteries, verify they are oriented correctly by following the (+) and (-) signs on the camera.
Remove the screw located under the rubber flap on the left side of the camera using a magnetic screwdriver.
Remove the two screws located on the other side of the camera using a magnetic screwdriver
Remove the three screws located at the bottom of the camera using a magnetic screwdriver.
Open the battery cover.
Using the iPod tool, push up gently around all edges of the camera.
Press and hold down the button shown in the blue circle.
While pressing the button, rotate the lens cover in a counter-clockwise direction to remove it.
5 andere personen hebben deze handleiding voltooid.
3 Opmerkingen
A handy guide. I had an A590IS with a broken battery door latch on the camera body, and I managed to obtain a dead A590IS with a fully intact latch for free. So using this guide I swapped the body shells over! All fixed and working again!
