Ga door naar hoofdinhoud
Disassembling Canon Pixma MP480 Rear and Side Panel
Wat je nodig hebt
  1. Disassembling Canon Pixma MP480 Rear and Side Panel, Rear and Side Panel: stap 1, afbeelding 1 van 2 Disassembling Canon Pixma MP480 Rear and Side Panel, Rear and Side Panel: stap 1, afbeelding 2 van 2
    • Remove the two 7.9 mm screws using a Phillips #1 screwdriver.
  2. Disassembling Canon Pixma MP480 Rear and Side Panel: stap 2, afbeelding 1 van 1
    • Lift up the back cover to remove it.
    • You may need to lift firmly as it requires quite a bit of force.
    "quite a bit of force" is almost an understatement, I found 2 clips along the bottom of that rear piece, one at the far left one around the middle (indicated by an arrow on the underside of the machine) - undoing these required much persistence with a screwdriver
    Perhaps Fuzz - Antwoord
    Thank you, Perhaps Fuzz. Thank you.
    Marji Zintz -
  3. Disassembling Canon Pixma MP480 Rear and Side Panel: stap 3, afbeelding 1 van 1
    • Open the front tray.
  4. Disassembling Canon Pixma MP480 Rear and Side Panel: stap 4, afbeelding 1 van 2 Disassembling Canon Pixma MP480 Rear and Side Panel: stap 4, afbeelding 2 van 2
    • Open the scanner compartment.
    • Make sure the blue lever locks into place to keep the compartment open.
  5. Disassembling Canon Pixma MP480 Rear and Side Panel: stap 5, afbeelding 1 van 2 Disassembling Canon Pixma MP480 Rear and Side Panel: stap 5, afbeelding 2 van 2
    • Remove the blue lever from its slot by pushing it back and twisting clockwise.
    • Close the scanner compartment and cover.
  6. Disassembling Canon Pixma MP480 Rear and Side Panel: stap 6, afbeelding 1 van 2 Disassembling Canon Pixma MP480 Rear and Side Panel: stap 6, afbeelding 2 van 2
    • Pry open the side cover with the plastic opening tool.
  7. Disassembling Canon Pixma MP480 Rear and Side Panel: stap 7, afbeelding 1 van 2 Disassembling Canon Pixma MP480 Rear and Side Panel: stap 7, afbeelding 2 van 2
    • Flip the printer over so that you are facing the bottom of the printer.
    • Use the plastic opening tool to remove the corner of the side panel from the plastic pin.
  8. Disassembling Canon Pixma MP480 Rear and Side Panel: stap 8, afbeelding 1 van 2 Disassembling Canon Pixma MP480 Rear and Side Panel: stap 8, afbeelding 2 van 2
    • Use the plastic opening tool to loosen the side panel from the bottom of the printer.
Conclusie
6 andere personen hebben deze handleiding voltooid.
Kevin Cole
116 Reputatie
1 Handleiding geschreven
Cal Poly, Team 19-41, Regan Winter 2013 Lid van Cal Poly, Team 19-41, Regan Winter 2013
CPSU-REGAN-W13S19G41
4 Leden
6 handleidingen geschreven
2 opmerkingen
Where is the rest of disassembly?
bill roberts - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 23
Altijd: 21,142
