Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Onderdelen & Gereedschap
Inleiding
Use this guide to replace a damaged front cover or to access the inner parts of the camera.
Onderdelen
Geen onderdelen opgegeven.
  1. Remove the two 3mm (1/8") black screws from the side cover using a #00 Phillips screwdriver.
    • Remove the two 3mm (1/8") black screws from the side cover using a #00 Phillips screwdriver.
  2. On the bottom, remove the 6mm (13/64") screw with the #00 Phillips Screwdriver.
    • On the bottom, remove the 6mm (13/64") screw with the #00 Phillips Screwdriver.
    • Pry up the panel; starting from the front/bottom corner, as indicated.
    • There's a concealed lip, under the opposite edge.
  3. LCD iPhone-scherm fixkits
    De goedkope optie, ondersteund door onze levenslange garantie.
    Koop kits
    Bespaar op reparatiekosten, niet op kwaliteit.
    Koop kits
  4. Remove three medium length screws from the bottom of the camera
    • Remove three medium length screws from the bottom of the camera
  5. Remove the two medium length screws on the front panel of the camera above the lens mount.
    • Remove the two medium length screws on the front panel of the camera above the lens mount.
    • Once you done, you may use the Spudger to panel from non-grip side.
    • If you start on the grip side, it will be more challenging to loosen the panel.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Daniel Bussone
1.239 Reputatie
11 handleidingen geschreven
Cal Poly, Team 3-41, Regan Winter 2011 Lid van Cal Poly, Team 3-41, Regan Winter 2011
CPSU-REGAN-W11S3G41
2 Leden
21 handleidingen geschreven
This should be labelled: Easy.
tjt263 - Antwoord
Okay, there are several steps missing.
tjt263 - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 15
Altijd: 4,666
