Inleiding
Use this guide to repair a broken battery door. The battery door on this model tends to break off due to a weak plastic hinge.
Gereedschap
Onderdelen
Geen onderdelen opgegeven.
Remove the two 3mm (1/8") black screws from the side cover using a #00 Phillips screwdriver.
Remove three medium length screws from the bottom of the camera
Remove the two 4.5mm (.18in) long black screws from the camera grip using a #00 Phillips screwdriver.
Remove the 4.8mm (.19in) long silver screw from the inside of the grip.
Bijna klaar!
Conclusie
