Ga door naar hoofdinhoud
Disassembling Canon EOS 60D Removing Back Panel
Wat je nodig hebt
  1. Disassembling Canon EOS 60D Removing Back Panel, Eye piece and Battery door: stap 1, afbeelding 1 van 2 Disassembling Canon EOS 60D Removing Back Panel, Eye piece and Battery door: stap 1, afbeelding 2 van 2
    • Removing the eyepiece is easy. There are two methods, you can do it yourself, or put it in your camera bag a dozen times and at least once, it will fall off.
    • Grip the eyepiece by the sides firmly (index finger and thumb). Wiggle it upwards until it is off.
  2. Disassembling Canon EOS 60D Removing Back Panel: stap 2, afbeelding 1 van 2 Disassembling Canon EOS 60D Removing Back Panel: stap 2, afbeelding 2 van 2
    • Open the battery door
    • Rotate the door so the one side of the hinge pops out (see photo #2)
    • Slide other pin out (it pops out the same, but this is easier)
  3. Disassembling Canon EOS 60D Removing Back Panel, Rubber grips: stap 3, afbeelding 1 van 1
    • Use a thin piece of plastic, spudger, or fingernail (if you have them) to lift up the edge of the grip, and pull up slowly.
    • Repeat for the other two grips
    • The large one on the battery-side is the easiest to start with. This is required to remove the front & back panels
    • The small one on the back is a bit difficult to get started, but not really difficult to remove.
    • The one on the AV panel will be easier if you open up the AV port cover.
    • Remove the adhesive like you would rubber cement, just rub your finger against it, it will come off.
    • Optionally throw the balled up adhesive at people pretending its a booger :)
  4. Disassembling Canon EOS 60D Removing Back Panel, Left-Side Port Cover: stap 4, afbeelding 1 van 1
    • Remove 3 screws
    • Remove the small Screw under the Flip cover too
  5. Disassembling Canon EOS 60D Removing Back Panel: stap 6, afbeelding 1 van 1
    • Using a Spudger, fingernail, or other thin plastic tool to wedge the panel off of the camera
    • Start at the camera's front. Pulling on the rubber av-cover may be enough to get it to move off the body
    • Only pull about 1/4" (3-5mm). There is a tab that will need to slide out
  6. Disassembling Canon EOS 60D Removing Back Panel: stap 7, afbeelding 1 van 1
    • Slide the rear part of the cover out.
  7. Disassembling Canon EOS 60D Removing Back Panel: stap 8, afbeelding 1 van 2 Disassembling Canon EOS 60D Removing Back Panel: stap 8, afbeelding 2 van 2
    • At this point, the only thing holding on is the dust-cover is hooked onto the front panel
    • Slide down to remove without damaging the cover. (see photo with cover removed)
    • You can see how the cover, and side piece fit together in the second image.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Eric D
1.284 Reputatie
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 13
Altijd: 5,019
