Ga door naar hoofdinhoud
Disassembling Breville BKC600XL Coffee Brewer Head
Wat je nodig hebt
  1. Disassembling Breville BKC600XL Coffee Brewer Head, "Bottom" Black Shell Piece: stap 1, afbeelding 1 van 3 Disassembling Breville BKC600XL Coffee Brewer Head, "Bottom" Black Shell Piece: stap 1, afbeelding 2 van 3 Disassembling Breville BKC600XL Coffee Brewer Head, "Bottom" Black Shell Piece: stap 1, afbeelding 3 van 3
    • Remove the two 12mm black Phillips screws using a Phillips #0 screwdriver.
    • Reminder for reassembly; This bottom piece is first to be screwed back on.
  2. Disassembling Breville BKC600XL Coffee Brewer Head, "Top" Black Shell Piece: stap 2, afbeelding 1 van 1
    • Remove the two 12mm Phillips screws using a Phillips #0 screwdriver.
  3. Disassembling Breville BKC600XL Coffee Brewer Head, Silver Casing: stap 3, afbeelding 1 van 3 Disassembling Breville BKC600XL Coffee Brewer Head, Silver Casing: stap 3, afbeelding 2 van 3 Disassembling Breville BKC600XL Coffee Brewer Head, Silver Casing: stap 3, afbeelding 3 van 3
    • Remove the grey plastic casing.
    • Remove the two 12mm hexagonal screws using a 1.5mm hex screwdriver.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Antonio
120 Reputatie
6 handleidingen geschreven
Cal Poly, Team 1-3, Propen Fall 2012 Lid van Cal Poly, Team 1-3, Propen Fall 2012
CPSU-PROPEN-F12S1G3
4 Leden
2 opmerkingen
Thanks so much for posting this! I was ready to throw my Breville out the window! Step three highlighted the closing mechanism and I was able to easily repair my machine!!
Thanks
acaltab - Antwoord
Does anyone know the name of the orange piece? And where I can get just that piece?
Ursula Nawab - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 4
Altijd: 4,136
