Ga door naar hoofdinhoud
Disassembling Black and Decker BL3000S Blender Base
Wat je nodig hebt
  1. Disassembling Black and Decker BL3000S Blender Base, Blender Base: stap 1, afbeelding 1 van 2 Disassembling Black and Decker BL3000S Blender Base, Blender Base: stap 1, afbeelding 2 van 2
    • Before disassembling the blender base, make sure the blender disconnected from any power outlet.
    • Lift the jar straight up from the base without tilting the jar.
  2. Disassembling Black and Decker BL3000S Blender Base: stap 2, afbeelding 1 van 1
    • Remove the top three 1/4 inch base screws using a Philip's head screwdriver.
  3. Disassembling Black and Decker BL3000S Blender Base: stap 3, afbeelding 1 van 2 Disassembling Black and Decker BL3000S Blender Base: stap 3, afbeelding 2 van 2
    • Remove the two base leg covers next to the power cord using pliers or a flat-head screwdriver.
    • This provides access to the base screws beneath.
  4. Disassembling Black and Decker BL3000S Blender Base: stap 4, afbeelding 1 van 1
    • Remove the following screws that secure the top and bottom halves of the base.
    • One 1/4 Phillips screw
    • One TA-20 screw
    • Both screwdrivers must have a minimum of a three inch shank (length).
    • Screwdrivers with extenders will not fit down the access holes.
  5. Disassembling Black and Decker BL3000S Blender Base: stap 5, afbeelding 1 van 1
    • Lift the top half of the base from the bottom half of the base to reveal the internal mechanism.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Andrew
209 Reputatie
4 handleidingen geschreven
Cal Poly, Team 6-34, Regan Fall 2012 Lid van Cal Poly, Team 6-34, Regan Fall 2012
CPSU-REGAN-F12S6G34
4 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 16
Afgelopen 30 dagen: 66
Altijd: 7,688
