Inleiding
How to dismantle, resolder power switch, and reassemble the BT 250 Baby Monitor
Wat je nodig hebt
Unclip the battery cover, and remove the batteries (they're a tight fit - the purple ribbon should help though)
Remove the two phillips screws at the lower edge of the battery compartment
The casing is now held together by a pair of snap-fixings on each side, which will require careful prising apart.
Using the picture as a guide to show where the catches are (red circles), use a small screwdriver or a spudger-type tool to release them levering outwards, then carefully separate the two halves of the casing
The LCD is held on by a pair of small plastic lugs, one each side. Release these one at a time, while gently lifting the LCD up from the board.
Once both clips are released, it will hinge forward and down.
Remove the two screws from under the LCD
Remove the single screw in the middle of the lower part of the PCB
Gently bend up the two charging connectors on the lower edge of the PCB that stick through the case to free it
Lift the PCB from the case, lower edge first
With the PCB removed, inspect the switches along the top edge.
On mine, the solder holding the switch mounting tabs to the PCB had failed, leaving both tabs and pads intact
Carefully resolder these, ensuring enough heat is applied to ensure a good joint, but without damaging neighbouring components
Reassembly is the reverse of dismantling.
Remember to bend the charging connectors back into place so they are correctly seated
Replace the vibrate motor into its' groove.
Ensure the switches all operate correctly before clipping the two case halves back together - sometimes the little pieces of adhesive foam on the 'button pressers' need to be adjusted.
