Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Remove the battery, then unscrew the 7 3 mm Phillips screws behind the battery. Make sure they go in separate, organized piles.
Unscrew the 2 4 mm Phillips head screws by the battery.
Remove the panel above the keyboard with a plastic spudger.
Once the panel is removed, use the spudger to pry out the keyboard.
Detach the ribbon cable from the keyboard by pulling the end of the ribbon cable that is attached inside of the laptop.
Now you can fully remove the keyboard from the laptop.
Place your fingers or a spudger between the front panel and the rest of the laptop.
Pull upwards gently to detach the side you are grabbing.
Repeat on the other side until the panel easily peels off the laptop.
