Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Inleiding
I did this to replace part of the screen assembly.
It's not as detailed as it should be, but I hope it will help you out a bit /give you an idea of what you are doing.
Make sure to read the entire guide before starting to give yourself an idea of what's where etc.
There are several fragile connectors and ribbon cables. You also do not want to pry the copper heatsink off of the processor.
Wat je nodig hebt
Case back removed from tablet
Remove the back with your fingernails, popping it open between the black border, and the plastic backing.
Be careful near the buttons and headphone jack.
Start by taking the screws from around the frame off.
Then remove the screws from this PCB
If you are replacing screen components, skip to step 7
Remove the little foam pads from the two connectors on the PCB These are for the digitizer
Flip up the releases on the plugs to pull out the ribbon cable. (I will show some more detailed pictures of the same process on other connectors.
Pic 1 - PCBs removed. Screen assembly and frame only.
Pic 2 - Screen assembly only.
Carefully peel silver tape off of black tape.
Starting at the right (in the picture) peel up the black tape. Be careful! The power ribbon cable for the backlight is hidden under at the left side. See next step for location of connection.
Hope this helped a bit.
I Could not find a guide, so I figured I'd make my own.
17 andere personen hebben deze handleiding voltooid.
30 opmerkingen
So you are on step 7?
The digitizer is the whole front panel. The LCD is sandwiched between that and the backlight. (The big white panel)
Around the edge, the backlight sort of clips into the frame. Try using a small blade screwdriver to pop the clips.
B0NK3R5 -
OK i found the problem an done the rest but the tablet didnt start. I think ther is a problem with the cabel´s but i can´t find it. When i push 2 cabels on the backside the screen works but the Touch didn´t work . What is the Problem ? I have buyed this Part
http://www.ebay.de/itm/321001110973?ssPa... . It is the right part for my Asus TF 300 but why zhe touch doesent work
Did you connect the ribbon cables to the main board?
B0NK3R5 -
