Ga door naar hoofdinhoud
Disassembling Arnova 7K G3 Motherboard
Wat je nodig hebt
  1. Disassembling Arnova 7K G3 Motherboard, Rear Cover: stap 1, afbeelding 1 van 3 Disassembling Arnova 7K G3 Motherboard, Rear Cover: stap 1, afbeelding 2 van 3 Disassembling Arnova 7K G3 Motherboard, Rear Cover: stap 1, afbeelding 3 van 3
    • Remove four 5 mm Phillips #00 screws from each corner of the tablet.
  2. Disassembling Arnova 7K G3 Motherboard: stap 2, afbeelding 1 van 2 Disassembling Arnova 7K G3 Motherboard: stap 2, afbeelding 2 van 2
    • Place the iFixit opening tool in the notches between the cases and pull the covers apart.
  3. Disassembling Arnova 7K G3 Motherboard: stap 3, afbeelding 1 van 1
    • Repeat step two until 3/4 of the rear cover is unlatched.
    • Proceed to remove the rear cover by gently pulling it apart by hand.
  4. Disassembling Arnova 7K G3 Motherboard, Disassembling Arnova 7K G3 Logic Board Ribbon Connectors: stap 4, afbeelding 1 van 2 Disassembling Arnova 7K G3 Motherboard, Disassembling Arnova 7K G3 Logic Board Ribbon Connectors: stap 4, afbeelding 2 van 2
    • Peel the copper tape covering the ribbon connector with a set of tweezers.
  5. Disassembling Arnova 7K G3 Motherboard: stap 5, afbeelding 1 van 3 Disassembling Arnova 7K G3 Motherboard: stap 5, afbeelding 2 van 3 Disassembling Arnova 7K G3 Motherboard: stap 5, afbeelding 3 van 3
    • Locate the two gray pins on the ribbon connector.
    • Grab the first pin with tweezers and gently pull it towards the ribbon. Repeat the step.
    • Gently pull the ribbon cable out of the connection port.
  6. Disassembling Arnova 7K G3 Motherboard: stap 6, afbeelding 1 van 3 Disassembling Arnova 7K G3 Motherboard: stap 6, afbeelding 2 van 3 Disassembling Arnova 7K G3 Motherboard: stap 6, afbeelding 3 van 3
    • Locate the ribbon connector two.
    • Locate the pins of ribbon connector two. Repeat step two for unlocking the pins.
    • Gently pull the ribbon out of the connection port.
  7. Disassembling Arnova 7K G3 Motherboard, Disassembling Arnova 7K G3 Motherboard: stap 7, afbeelding 1 van 1
    • Remove the two Phillips #00 screws from the motherboard.
  8. Disassembling Arnova 7K G3 Motherboard: stap 8, afbeelding 1 van 1
    • Gently lift up the motherboard and reorient it in a more efficient manner in order to locate the desired components.
Conclusie
Kue
301 Reputatie
3 handleidingen geschreven
Michigan Tech, Team 1-2, Lauer Spring 2015 Lid van Michigan Tech, Team 1-2, Lauer Spring 2015
MTU-LAUER-S15S1G2
2 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 404
