Ga door naar hoofdinhoud
Disassembling ASUS MeMO Pad 7 (ME572C) Rear Panel
Wat je nodig hebt
  1. Disassembling ASUS MeMO Pad 7 (ME572C) Rear Panel, Rear Panel: stap 1, afbeelding 1 van 2 Disassembling ASUS MeMO Pad 7 (ME572C) Rear Panel, Rear Panel: stap 1, afbeelding 2 van 2
    • Make sure your device is turned off. Then with a plastic opening tool, carefully remove the back panel by carefully working your way around the perimeter.
    • The panel will be glued on and requires pressure to open.
  2. Disassembling ASUS MeMO Pad 7 (ME572C) Rear Panel: stap 2, afbeelding 1 van 3 Disassembling ASUS MeMO Pad 7 (ME572C) Rear Panel: stap 2, afbeelding 2 van 3 Disassembling ASUS MeMO Pad 7 (ME572C) Rear Panel: stap 2, afbeelding 3 van 3
    • After removing the rear panel, use a plastic openning tool to remove the frame of the tablet.
    • Start in the middle of the top side and insert a plastic opening tool between the screen and the frame.
    • Carefully run the plastic opening tool along all the edges of the tablet.
  3. Disassembling ASUS MeMO Pad 7 (ME572C) Rear Panel: stap 3, afbeelding 1 van 1
    • When you take the rear panel and the frame out, place the rear panel and the frame away from the device.
Conclusie
8 andere personen hebben deze handleiding voltooid.
Efe Guldogan
860 Reputatie
4 handleidingen geschreven
USF Tampa, Team 14-23, Meier Fall 2015 Lid van USF Tampa, Team 14-23, Meier Fall 2015
USFT-MEIER-F15S14G23
4 Leden
14 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 40
Altijd: 13,634
