Ga door naar hoofdinhoud
Direct-Drive Turntable Cartridge and Needle Replacement
Wat je nodig hebt
  1. Direct-Drive Turntable Cartridge and Needle Replacement, Cartridge and Needle: stap 1, afbeelding 1 van 1
    • Check the needle and cartridge to see if they need to be replaced.
    • If the cartridge is touching your vinyl, it must be replaced.
    • Additionally, if you can hear scraping when playing the record, or if you see new scratch marks on the vinyl, it is time to change the cartridge and needle.
  2. Direct-Drive Turntable Cartridge and Needle Replacement: stap 2, afbeelding 1 van 3 Direct-Drive Turntable Cartridge and Needle Replacement: stap 2, afbeelding 2 van 3 Direct-Drive Turntable Cartridge and Needle Replacement: stap 2, afbeelding 3 van 3
    • Manually unscrew the bulb on the tone arm from the headshell.
    • Pull out the headshell once it is completely unscrewed from the tone arm.
  3. Direct-Drive Turntable Cartridge and Needle Replacement: stap 3, afbeelding 1 van 3 Direct-Drive Turntable Cartridge and Needle Replacement: stap 3, afbeelding 2 van 3 Direct-Drive Turntable Cartridge and Needle Replacement: stap 3, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Flathead 3/32" or 2.5 mm Screwdriver
    $5.49
    Koop
    • Use a 2.5 mm flathead screwdriver to remove both screws from the headshell.
  4. Direct-Drive Turntable Cartridge and Needle Replacement: stap 4, afbeelding 1 van 2 Direct-Drive Turntable Cartridge and Needle Replacement: stap 4, afbeelding 2 van 2
    • Gently pull the four wires out from the back of the cartridge.
  5. Direct-Drive Turntable Cartridge and Needle Replacement: stap 5, afbeelding 1 van 2 Direct-Drive Turntable Cartridge and Needle Replacement: stap 5, afbeelding 2 van 2
    • Pull the needle off of the new cartridge to ensure it does not get damaged during installation.
  6. Direct-Drive Turntable Cartridge and Needle Replacement: stap 6, afbeelding 1 van 3 Direct-Drive Turntable Cartridge and Needle Replacement: stap 6, afbeelding 2 van 3 Direct-Drive Turntable Cartridge and Needle Replacement: stap 6, afbeelding 3 van 3
    • Connect the wires on the headshell to the new cartridge by matching the colors of the wires to the pins on the cartridge.
    • Place the headshell back onto the cartridge, being sure to line up the holes for the screws.
    • Place the screws back into the holes connecting the headshell and the new cartridge.
  7. Direct-Drive Turntable Cartridge and Needle Replacement: stap 7, afbeelding 1 van 3 Direct-Drive Turntable Cartridge and Needle Replacement: stap 7, afbeelding 2 van 3 Direct-Drive Turntable Cartridge and Needle Replacement: stap 7, afbeelding 3 van 3
    • Screw the screws in using a 2.5 mm flathead screwdriver. Ensure the headshell is securely attached to the cartridge.
    • Slide the new needle back onto the cartridge.
  8. Direct-Drive Turntable Cartridge and Needle Replacement: stap 8, afbeelding 1 van 3 Direct-Drive Turntable Cartridge and Needle Replacement: stap 8, afbeelding 2 van 3 Direct-Drive Turntable Cartridge and Needle Replacement: stap 8, afbeelding 3 van 3
    • Attach the headshell to the tone arm and screw the headshell in from the tip of the tone arm.
    • Ensure that the headshell is secured in the tone arm and that there is no movement in the headshell when connected to the tone arm.
  9. Direct-Drive Turntable Cartridge and Needle Replacement: stap 9, afbeelding 1 van 1
    • Place the needle onto a vinyl record and ensure that only the tip of the needle is touching the record and not the cartridge.
Eindstreep
Dylan Udhesister
169 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 37
Altijd: 884
