Ga door naar hoofdinhoud
Digital2 Platinum Pad 9 Volume Buttons Replacement
Wat je nodig hebt
  1. Digital2 Platinum Pad 9 Volume Buttons Replacement, External Cover: stap 1, afbeelding 1 van 1
    • Take the plastic opening tool and insert it into the crease between the screen and the plastic casing and press down.
  2. Digital2 Platinum Pad 9 Volume Buttons Replacement: stap 2, afbeelding 1 van 2 Digital2 Platinum Pad 9 Volume Buttons Replacement: stap 2, afbeelding 2 van 2
    • After inserting the plastic opening tool, run it around the device a few times to loosen the external cover.
  3. Digital2 Platinum Pad 9 Volume Buttons Replacement: stap 3, afbeelding 1 van 2 Digital2 Platinum Pad 9 Volume Buttons Replacement: stap 3, afbeelding 2 van 2
    • Once you've gone around a few times a corner will pop up, insert the opening tool there and repeat step 2 with slightly more pressure. Do this until every section of the backing has popped up.
    • Then just remove the backing.
  4. Digital2 Platinum Pad 9 Volume Buttons Replacement, Volume Buttons: stap 4, afbeelding 1 van 1
    • You can locate the volume buttons on one of the longer sides of the tablet.
  5. Digital2 Platinum Pad 9 Volume Buttons Replacement: stap 5, afbeelding 1 van 1
    • Lift up the ZIF connector that is attached to the volume buttons ribbon cable.
  6. Digital2 Platinum Pad 9 Volume Buttons Replacement: stap 6, afbeelding 1 van 1
    • Then remove the ribbon cable from the ZIF connector.
  7. Digital2 Platinum Pad 9 Volume Buttons Replacement: stap 7, afbeelding 1 van 1
    • Make sure to separate the volume button's cable from the cable connecting the motherboard to the screen
  8. Digital2 Platinum Pad 9 Volume Buttons Replacement: stap 8, afbeelding 1 van 2 Digital2 Platinum Pad 9 Volume Buttons Replacement: stap 8, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • Then use the precision tweezers to grab the volume buttons.
    • Pull until the buttons come out.
Conclusie
David DeMeritt
637 Reputatie
6 handleidingen geschreven
UMass Dartmouth, Team 5-6, Landers Spring 2016 Lid van UMass Dartmouth, Team 5-6, Landers Spring 2016
UMASSD-LANDERS-S16S5G6
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 6
Altijd: 99
