Ga door naar hoofdinhoud
Digital2 Platinum Pad 9 External Cover Replacement
Wat je nodig hebt
  1. Digital2 Platinum Pad 9 External Cover Replacement, External Cover: stap 1, afbeelding 1 van 1
    • Take the plastic opening tool and insert it into the crease between the screen and the plastic casing and press down.
  2. Digital2 Platinum Pad 9 External Cover Replacement: stap 2, afbeelding 1 van 2 Digital2 Platinum Pad 9 External Cover Replacement: stap 2, afbeelding 2 van 2
    • After inserting the plastic opening tool, run it around the device a few times to loosen the external cover.
  3. Digital2 Platinum Pad 9 External Cover Replacement: stap 3, afbeelding 1 van 2 Digital2 Platinum Pad 9 External Cover Replacement: stap 3, afbeelding 2 van 2
    • Once you've gone around a few times a corner will pop up, insert the opening tool there and repeat step 2 with slightly more pressure. Do this until every section of the backing has popped up.
    • Then just remove the backing.
Conclusie
David DeMeritt
637 Reputatie
6 handleidingen geschreven
UMass Dartmouth, Team 5-6, Landers Spring 2016 Lid van UMass Dartmouth, Team 5-6, Landers Spring 2016
UMASSD-LANDERS-S16S5G6
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 6
Altijd: 290
