Ga door naar hoofdinhoud
Digital2 D2-912 Screen Replacement
Wat je nodig hebt
  1. Digital2 D2-912 Screen Replacement, External Cover: stap 1, afbeelding 1 van 1
    • Remove the two Phillips #00 screws from the bottom of the case.
  2. Digital2 D2-912 Screen Replacement: stap 2, afbeelding 1 van 2 Digital2 D2-912 Screen Replacement: stap 2, afbeelding 2 van 2
    • Wedge the opening tool in the space between the back and the front of the tablet.
    • Carefully work your way around the perimeter, wedging the opening tool between the front and back of the tablet.
    • When the back of the tablet is mostly detached from the front, carefully pull it away completely.
  3. Digital2 D2-912 Screen Replacement, Screen: stap 3, afbeelding 1 van 1
    • Be sure to remove the yellow tape that is holding the components down.
    • Locate the two yellow ribbon cables and carefully remove by lifting the black tab connectors forward and slide out ribbon.
    • When all components are unsecured, you will be able to remove the battery, motherboard, camera, and speaker out of the way.
    More detail about how to remove the yellow tab.
    Natalie Holm - Antwoord
  4. Digital2 D2-912 Screen Replacement: stap 4, afbeelding 1 van 1
    • Using the metal spudger, pry the display from the screen.
  5. Digital2 D2-912 Screen Replacement: stap 5, afbeelding 1 van 1
    • The screen is now ready to be replaced by the new one
Conclusie
Lindsay Richardson
394 Reputatie
3 handleidingen geschreven
IUPUI, Team 1-1, Harley Fall 2015 Lid van IUPUI, Team 1-1, Harley Fall 2015
IUPUI-HARLEY-F15S1G1
4 Leden
6 handleidingen geschreven
3 opmerkingen
Dear Lindsay,
thank you for the guide how to open up that little thing!
Apparently I have fried it after I had mislaid the charger and used my
universal charger without checking the voltage: 8 instead of 5... If only
I had used my reading glasses.
Is there something like a fuse that I could repair/exchange?
Thank you for your help!
Respectfully,
Wolfgang
Dr. Wolfgang Mohr - Antwoord
Thanks for the help, I am just curious where I can get the new screen, I believe that the front glass is fine but the actual display I am pretty sure is not.
Super Manny - Antwoord
This website right here. Straight trash,basically So you have a broken tablet. You come to the website to get help to replace it. And it's no help at all. This is what I think about this hot mass right here
Rocia Patrick - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 608
