Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Remove the two Phillips #00 screws from the bottom of the case.
Wedge the opening tool in the space between the back and the front of the tablet.
Carefully work your way around the perimeter, wedging the opening tool between the front and back of the tablet.
When the back of the tablet is mostly detached from the front, carefully pull it away completely.
Gereedschap gebruikt in deze stap:Desoldering Pump$3.99-
Remove the wires shown in the image, using a soldering iron and solder sucker.
Use the Phillips #00 screwdriver to remove the three screws from motherboard.
Detach the capacitive touch controller from the motherboard.
Carefully pry the narrow black connector upward to release the ribbon.
Remove the ribbon from the connector.
Locate the camera found in the image.
Carefully pry the black connector upward to release ribbon.
Remove the black tape to release the camera from the motherboard.
Remove and replace the motherboard.
