Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Inleiding
We will be taking out the entire motherboard of the tablet, in essence, the majority of the tablet. This requires carefully unbuckling lots of peripheral connectors.
Wat je nodig hebt
Refer to this Teardown Guide first to remove the cover:
Using a soldering iron and solder sucker, remove the wires indicated in the two red circles from the motherboard.
By removing the wires, you are detaching the battery and speaker from the motherboard.
Locate the camera found in the red circle.
Flip the black portion (indicated with arrow) of the connector up to release ribbon.
Remove the black tape to release the camera from the motherboard.
Remove ribbon from connector.
At this point, the motherboard should not be held down by anything else. Remove and replace the board.
