Wat je nodig hebt
The reading changes all the time, there is some dust or dirt in the sensor.
The problem is actually, how do you open it...
There is a very thick and well glued label on the back which hides the screws which need to be removed. Then it is easy.
When everything is disassembled, generally a cleaning of the surfaces is enough to make it work again.
Do not forget to readjust the screws tightening the sliding joint. Is is on the side.
Één andere persoon heeft deze handleiding voltooid.
