Wat je nodig hebt
Stap 1 Digiland 10.1'' DL1016 Remove Backing
Voorzichtig: stappen 1-2 komen van een handleiding die in bewerking is.
Use an opening pick and an opening tool to pry the backing off the back of the tablet.
Pull back the black flaps on the ZIF cable connectors.
Pull the ribbon cables out of the connectors.
Stap 4 Digiland 10.1'' DL1016 Remove Battery
Voorzichtig: stap 4 komt van een handleiding die in bewerking is.
There is glue that holds the battery down, so carefully pry it open. You may need to use some force.
Één opmerking
Where I can buy this battery ? From the screenshot it looks to be a fit for a Tanoshi 2 in 1 computer
