Ga door naar hoofdinhoud
DigiTech RP70 Motherboard Replacement
Wat je nodig hebt
  1. DigiTech RP70 Motherboard Replacement, Motherboard: stap 1, afbeelding 1 van 2 DigiTech RP70 Motherboard Replacement, Motherboard: stap 1, afbeelding 2 van 2
    • Unplug the device from its AC power adapter; unplug anything connected to the input/output jacks.
    • Remove the four 8mm Phillips #0 screws located on the back panel.
  2. DigiTech RP70 Motherboard Replacement: stap 2, afbeelding 1 van 2 DigiTech RP70 Motherboard Replacement: stap 2, afbeelding 2 van 2
    • Remove the back panel to expose the motherboard.
  3. DigiTech RP70 Motherboard Replacement: stap 3, afbeelding 1 van 1
    • Remove the two 11mm #0 Phillips screws located at the bottom of the motherboard.
  4. DigiTech RP70 Motherboard Replacement: stap 4, afbeelding 1 van 1
    • Lift the indented end of the motherboard opposite the input/output jacks. Then, pull away from the input/output jacks to slide the motherboard out of the casing.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
3 opmerkingen
My digitech rp 80 not work. How to get new motherboard
Thadevus - Antwoord
My digitecj rp 80 not working. No display no sound how to get new motherboard
Thadevus - Antwoord
Does anyone know where I can get the tone library push button/knob assy? Mine broke off.
Michael Adkins - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 9
Altijd: 744
