Ga door naar hoofdinhoud
DigiLand DL801W Battery Replacement
Wat je nodig hebt
  1. DigiLand DL801W Battery Replacement, Speaker: stap 1, afbeelding 1 van 1
    • Before opening your DigiLand Tablet, ensure that the MicroSD card is removed.
    • Hold the tablet in one hand (not your primary hand) so that the bottom edge of the tablet is facing you and the back of the tablet is facing up.
    • Using a blue plastic opening tool, gently insert the tool between the back panel and the main body.
    • Going around the edge of the tablet, gently pry open the back panel. As you go around, you will hear a click.
  2. DigiLand DL801W Battery Replacement: stap 2, afbeelding 1 van 1
    • Remove the two JIS #000 screws that hold the speaker bracket in place. Be sure to place the screws in a safe place to avoid losing them.
    • Where the red and black wires connect to the motherboard, use a soldering iron to remove the defective speaker.
    • Complete removal of the speaker from the motherboard is not necessary. It is just recommended that the bracket be removed to allow more room for battery removal.
  3. DigiLand DL801W Battery Replacement, Battery: stap 3, afbeelding 1 van 1
    • Using the black spudger, insert the flat edge between the battery and the metal plate. Continue until the battery is completely separated from the metal plate.
    • Once the battery is separated from the metal plate, it is safe to detach the wires from the motherboard.
    • When attaching the new battery, ensure the metal plate is clean and free of debris.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Travis Mangum
572 Reputatie
4 handleidingen geschreven
IUPUI, Team 3-4, Harley Fall 2015 Lid van IUPUI, Team 3-4, Harley Fall 2015
IUPUI-HARLEY-F15S3G4
4 Leden
10 handleidingen geschreven
2 opmerkingen
all you have to do to open this tablet is put a very small flat head screwdriver in the headphone jack and turn it. the top and bottom plastic covers will separate. you don’t need any special tools.
greensburgjoy - Antwoord
Hola, me gustaría saber dónde puedo comprar la batería.
GraciasHola, me gustaría saber dónde puedo comprar la batería. Gracias
yo_jaisan - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 16
Altijd: 7,067
