Ga door naar hoofdinhoud
Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement
Wat je nodig hebt
  1. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement, Unplug: stap 1, afbeelding 1 van 1
    • Before you start, remember to disconnect the outlet from the mains.
  2. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: stap 2, afbeelding 1 van 2 Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: stap 2, afbeelding 2 van 2
    • Remove the dust box and the seal on the back of the device.
  3. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: stap 3, afbeelding 1 van 3 Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: stap 3, afbeelding 2 van 3 Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: stap 3, afbeelding 3 van 3
    • Unscrew the six screws of the pad.
    • Lock the motor with a screwdriver to be able to unscrew the centre screw, you will not be able to get there without blocking the gear.
  4. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: stap 4, afbeelding 1 van 2 Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: stap 4, afbeelding 2 van 2
    • Using a screwdriver or screwdriver, unscrew and open the device.
    • Lift the two carbons with a screwdriver to get them out of their homes.
    • Remove the rotor from its housing.
    • Press the tab to disconnect the coal from the engine.
    • Unscrew the domino screws to disconnect the cables.
    • Use a clamp to extract the cables.
  5. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: stap 9, afbeelding 1 van 1
    • Separate the wire connected to the motor.
    • Cut the rat cable with a cutting pliers.
  6. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: stap 11, afbeelding 1 van 2 Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: stap 11, afbeelding 2 van 2
    • Unsolder the cable connected to the speed dimmer.
    • Approach the soldering iron to heat the tin and make it soft. Using the pump, remove the residues.
  7. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: stap 13, afbeelding 1 van 1
    • Take out the old engine to replace it with the new one.
  8. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: stap 14, afbeelding 1 van 3 Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: stap 14, afbeelding 2 van 3 Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: stap 14, afbeelding 3 van 3
    • Replace the cable of the new motor on the speed dimmer.
    • You must take the shortest cable.
    • With tin, unsolder the wire on the frame to hold it.
    • Replace the speed dimmer in its housing.
  9. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: stap 17, afbeelding 1 van 3 Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: stap 17, afbeelding 2 van 3 Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: stap 17, afbeelding 3 van 3
    • Replace the most black thread in the domino.
  10. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: stap 18, afbeelding 1 van 1
    • Replace each room in its housing.
    • Reconnect the carbons.
  11. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: stap 20, afbeelding 1 van 2 Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: stap 20, afbeelding 2 van 2
    • Replace the new engine.
    • Remember to recover the small washer at the end of the old piece.
  12. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: stap 21, afbeelding 1 van 1
    • Replace the engine at its location.
  13. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: stap 22, afbeelding 1 van 3 Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: stap 22, afbeelding 2 van 3 Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: stap 22, afbeelding 3 van 3
    • Be careful to put the black cable back into its housing so as not to block during the reassembly of the machine.
    • Put the carbons back in their place.
  14. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: stap 24, afbeelding 1 van 3 Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: stap 24, afbeelding 2 van 3 Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: stap 24, afbeelding 3 van 3
    • Replace the shell, then screw it back on.
    • Remember to put the joint back in its place.
  15. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: stap 25, afbeelding 1 van 2 Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: stap 25, afbeelding 2 van 2
    • Reposition the part, then lock the engine with a screwdriver to screw.
    • Put the tray back on and screw the screws.
  16. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: stap 26, afbeelding 1 van 1
    • Finally, reposition the vacuum bag.
Eindstreep
Met dank aan deze vertalers:
fr en
100%
HelloMacOS helpt ons de wereld te herstellen! Wil je bijdragen?
Begin met vertalen ›
Céline Chemineau
16.581 Reputatie
95 handleidingen geschreven
Leroy Merlin Lid van Leroy Merlin
Community
36 Leden
239 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 146
