Ga door naar hoofdinhoud
Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System
Wat je nodig hebt
  1. Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System, Unplug: stap 1, afbeelding 1 van 1
    • Before starting, remember to disconnect the outlet from the mains.
  2. Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: stap 2, afbeelding 1 van 3 Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: stap 2, afbeelding 2 van 3 Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: stap 2, afbeelding 3 van 3
    • Remove the handle, unscrewing the screw
  3. Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: stap 3, afbeelding 1 van 2 Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: stap 3, afbeelding 2 van 2
    • Remove the strip by leverling
  4. Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: stap 4, afbeelding 1 van 1
    • Remove the front cover to have more space.
  5. Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: stap 5, afbeelding 1 van 1
    • Remove the two screws on the shell.
  6. Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: stap 6, afbeelding 1 van 1
    • Turn the machine over and unscrew the large screw.
    • Unscrew the orange wheel to be able to lift it.
  7. Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: stap 8, afbeelding 1 van 1
    • Remove the spring from the old part to put it back on the new one.
  8. Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: stap 9, afbeelding 1 van 1
    • Put the spring back.
    • Tighten the orange wheel.
  9. Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: stap 11, afbeelding 1 van 1
    • Put the two screws back on the side and the large screw.
  10. Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: stap 12, afbeelding 1 van 3 Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: stap 12, afbeelding 2 van 3 Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: stap 12, afbeelding 3 van 3
    • Replace the tip, strip and handle.
Eindstreep
Met dank aan deze vertalers:
fr en
100%
HelloMacOS helpt ons de wereld te herstellen! Wil je bijdragen?
Begin met vertalen ›
Céline Chemineau
16.581 Reputatie
95 handleidingen geschreven
Leroy Merlin Lid van Leroy Merlin
Community
36 Leden
239 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 11
Altijd: 305
