Ga door naar hoofdinhoud
Dexter Corded Belt Sander - 900BS2.5 Motor Replacement
Wat je nodig hebt
  1. Dexter Corded Belt Sander - 900BS2.5 Motor Replacement, Unplug: stap 1, afbeelding 1 van 1
    • Before you begin, remember to disconnect the mains plug.
  2. Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: stap 2, afbeelding 1 van 3 Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: stap 2, afbeelding 2 van 3 Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: stap 2, afbeelding 3 van 3
    • Remove the handle, by unscrewing the screw.
  3. Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: stap 3, afbeelding 1 van 2 Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: stap 3, afbeelding 2 van 2
    • Pry the tape off.
  4. Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: stap 4, afbeelding 1 van 1
    • Unscrew the 4 screws.
  5. Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: stap 5, afbeelding 1 van 2 Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: stap 5, afbeelding 2 van 2
    • Remove the belt, then unscrew the screws of the shell to gain access to the motor.
    • Collect the belt to place it in the new room.
  6. Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: stap 6, afbeelding 1 van 3 Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: stap 6, afbeelding 2 van 3 Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: stap 6, afbeelding 3 van 3
    • Remove both accessories.
  7. Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: stap 7, afbeelding 1 van 2 Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: stap 7, afbeelding 2 van 2
    • Remove the screws from the hull in order to have access to the interior and allow the carbon brushes to be blocked.
    • Relax the small metal strip to be able to separate the carbons.
    • Replace the new part in its housing.
  8. Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: stap 10, afbeelding 1 van 2 Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: stap 10, afbeelding 2 van 2
    • Open the cap of the new part to replace the belt.
    • Tighten the inner screw.
  9. Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: stap 11, afbeelding 1 van 1
    • Tighten the four screws.
  10. Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: stap 12, afbeelding 1 van 3 Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: stap 12, afbeelding 2 van 3 Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: stap 12, afbeelding 3 van 3
    • Replace the tip, band and handle.
Eindstreep
Met dank aan deze vertalers:
fr en
100%
HelloMacOS helpt ons de wereld te herstellen! Wil je bijdragen?
Begin met vertalen ›
Céline Chemineau
16.581 Reputatie
95 handleidingen geschreven
Leroy Merlin Lid van Leroy Merlin
Community
36 Leden
239 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 8
Altijd: 115
