Ga door naar hoofdinhoud
Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Stabiliser
Wat je nodig hebt
  1. Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Stabiliser, Unplug: stap 1, afbeelding 1 van 1
    • Before starting, remember to disconnect the outlet from the mains.
  2. Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Stabiliser: stap 2, afbeelding 1 van 2 Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Stabiliser: stap 2, afbeelding 2 van 2
    • Remove the dust case on the back of the device.
  3. Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Stabiliser: stap 3, afbeelding 1 van 3 Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Stabiliser: stap 3, afbeelding 2 van 3 Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Stabiliser: stap 3, afbeelding 3 van 3
    • Unscrew the six screws from the pad.
    • Lock the motor with a screwdriver to be able to unscrew the centre screw, you will not be able to get there without blocking the gear.
  4. Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Stabiliser: stap 4, afbeelding 1 van 2 Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Stabiliser: stap 4, afbeelding 2 van 2
    • Remove the four stabilisers by hand.
  5. Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Stabiliser: stap 5, afbeelding 1 van 2 Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Stabiliser: stap 5, afbeelding 2 van 2
    • The stabilisers make sense, so be careful when replacing them.
    • Replace them directly on the pad for ease.
  6. Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Stabiliser: stap 6, afbeelding 1 van 2 Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Stabiliser: stap 6, afbeelding 2 van 2
    • Reposition the part, then lock the engine with a screwdriver to screw.
    • Put the tray back on and screw the screws.
  7. Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Stabiliser: stap 7, afbeelding 1 van 1
    • Finally, reposition the vacuum bag.
Eindstreep
Met dank aan deze vertalers:
fr en
100%
HelloMacOS helpt ons de wereld te herstellen! Wil je bijdragen?
Begin met vertalen ›
Céline Chemineau
16.581 Reputatie
95 handleidingen geschreven
Leroy Merlin Lid van Leroy Merlin
Community
36 Leden
239 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 17
Altijd: 378
