Wat je nodig hebt
Using a spudger, unplug the Charging Port connector from the motherboard.
5 opmerkingen
Where can the part be purchased?
I'm not sure if there is a replacement charging port assembly available online. If you're good at microsoldering, you could replace the surface mount micro USB port on the assembly.
Andrew S -
where can the part be purchased?
would a cell phone repair shop be able to do this?
If they are comfortable with it. Tell them it will probably require microsoldering.
Andrew S -
