Ga door naar hoofdinhoud
Dewalt DCF885 Brush Assembly Replacement
Wat je nodig hebt
  1. Dewalt DCF885 Brush Assembly Replacement, Battery: stap 1, afbeelding 1 van 1
    • Press the battery release button at the top of the battery.
  2. Dewalt DCF885 Brush Assembly Replacement: stap 2, afbeelding 1 van 1
    • Pull the battery away from the tool.
  3. Dewalt DCF885 Brush Assembly Replacement, Motor Assembly: stap 3, afbeelding 1 van 1
    • Remove the eight 18 mm Torx Security #10 screws.
  4. Dewalt DCF885 Brush Assembly Replacement: stap 4, afbeelding 1 van 1
    • Separate the two halves of the outer case. Set the empty side down and out of the way.
  5. Dewalt DCF885 Brush Assembly Replacement: stap 5, afbeelding 1 van 1
    • Disconnect the connector from the motor assembly.
  6. Dewalt DCF885 Brush Assembly Replacement: stap 6, afbeelding 1 van 1
    • Pull the motor away from the brush assembly.
  7. Dewalt DCF885 Brush Assembly Replacement, Brush Assembly: stap 7, afbeelding 1 van 1
    • Lift the brush assembly out of the drill case.
  8. Dewalt DCF885 Brush Assembly Replacement: stap 8, afbeelding 1 van 1
    • Pull the armature assembly apart from the brush ring assembly.
  9. Dewalt DCF885 Brush Assembly Replacement: stap 9, afbeelding 1 van 1
    • Pry the two circled connectors apart from the brush ring assembly.
  10. Dewalt DCF885 Brush Assembly Replacement: stap 10, afbeelding 1 van 1
    • The brush assembly is now removed from the drill body.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Één opmerking
Can you tell me the exact model number of the unit in this tutorial? And/Or the part number for that switch assembly? I cannot find that specific switch assembly anywhere! Thank you.
Derek Tombrello - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 24
Altijd: 2,240
