Ga door naar hoofdinhoud
Inleiding
If you need to replace a part within the Dewalt DCD778 then you need to remove the outer shell of the drill. By following this guide you will know how to take apart the outer casing to access the internal components of the drill that you wish to replace.
Onderdelen
Geen onderdelen opgegeven.
  1. Compress the button on front side of the battery and move the drill and battery away from each other.
    • Compress the button on front side of the battery and move the drill and battery away from each other.
  2. Remove the battery from drill by sliding the battery outwards away from the drill.
    • Remove the battery from drill by sliding the battery outwards away from the drill.
  3. Remove the eight 16 mm screws by using a Torx Security #15 screwdriver.
    • Remove the eight 16 mm screws by using a Torx Security #15 screwdriver.
  4. Lay the drill on its side and gently lift the top half off it.
    • Lay the drill on its side and gently lift the top half off it.
Conclusie
Brittany
630 Reputatie
5 handleidingen geschreven
0 Opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 166
