Ga door naar hoofdinhoud
Dewalt DCD778 Forward/Reverse Switch Replacement
Wat je nodig hebt
  1. Dewalt DCD778 Forward/Reverse Switch  Replacement, Battery: stap 1, afbeelding 1 van 1
    • Grab the drill in one hand and cup the battery (located at the bottom of the drill) with the other hand.
  2. Dewalt DCD778 Forward/Reverse Switch  Replacement: stap 2, afbeelding 1 van 1
    • Use your other hand to push down on the yellow button on the battery.
  3. Dewalt DCD778 Forward/Reverse Switch  Replacement: stap 3, afbeelding 1 van 1
    • Pull the battery in a horizontal direction away from the drill.
  4. Dewalt DCD778 Forward/Reverse Switch  Replacement, Forward/Reverse Switch: stap 4, afbeelding 1 van 1
    • Remove the eight 16 mm, Torx Security #15 screws.
  5. Dewalt DCD778 Forward/Reverse Switch  Replacement: stap 5, afbeelding 1 van 1
    • Lay the drill on its side and gently lift the top half off it.
  6. Dewalt DCD778 Forward/Reverse Switch  Replacement: stap 6, afbeelding 1 van 1
    • Remove the drill mechanism from the shell.
  7. Dewalt DCD778 Forward/Reverse Switch  Replacement: stap 7, afbeelding 1 van 1
    • Disconnect the forward/reverse switch from the trigger by pulling the mechanism out and leaving the switch in the frame.
    • To replace just pull the switch out and put the new one in the opening.
Conclusie
Brittany
693 Reputatie
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 47
Altijd: 1,670
