Ga door naar hoofdinhoud
Desktop PC Left Panel Replacement
Wat je nodig hebt
  1. Desktop PC Left Panel Replacement, Left Panel: stap 1, afbeelding 1 van 1
    • Unplug the computer from the power supply before any maintenance or disassembly.
    • Remove the two Phillips #2 head 5mm screws from the back side of the computer case. You only need to remove the screws that hold down the panel.
    • These screws can usually be removed by hand.
    • Be sure to wear an anti-static bracelet or use an anti-static mat to ensure important components are not damaged by static electricity.
  2. Desktop PC Left Panel Replacement: stap 2, afbeelding 1 van 2 Desktop PC Left Panel Replacement: stap 2, afbeelding 2 van 2
    • Next, remove the side panel of the computer case to allow access into the computer. Slide the panel towards the back of the computer and lift it up to remove.
    • If there is a fan mounted on the side panel, make sure to unplug the cable before fully removing the panel.
Conclusie
22 andere personen hebben deze handleiding voltooid.
David Lennon
9.713 Reputatie
10 handleidingen geschreven
Cal Poly, Team 4-5, Maness Spring 2015 Lid van Cal Poly, Team 4-5, Maness Spring 2015
CPSU-MANESS-S15S4G5
4 Leden
35 handleidingen geschreven
3 opmerkingen
What is the name of the case used in this tutorial?
Nicolas Hunter - Antwoord
I would also like to know, I saved one of these from a junk pile but not sure what it is? Was able to fit a full ATX board with gtx570 and a little breathing room so not too shabby for how small it is.
Wabbajack Wabbajack - Antwoord
I have this same case in black and want to know what model it is.
numanair - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 21
Afgelopen 30 dagen: 85
Altijd: 4,275
