Ga door naar hoofdinhoud
Desktop PC Graphics Card Replacement
Wat je nodig hebt
  1. Desktop PC Graphics Card Replacement, Left Panel: stap 1, afbeelding 1 van 1
    • Unplug the computer from the power supply before any maintenance or disassembly.
    • Remove the two Phillips #2 head 5mm screws from the back side of the computer case. You only need to remove the screws that hold down the panel.
    • These screws can usually be removed by hand.
    • Be sure to wear an anti-static bracelet or use an anti-static mat to ensure important components are not damaged by static electricity.
  2. Desktop PC Graphics Card Replacement: stap 2, afbeelding 1 van 2 Desktop PC Graphics Card Replacement: stap 2, afbeelding 2 van 2
    • Next, remove the side panel of the computer case to allow access into the computer. Slide the panel towards the back of the computer and lift it up to remove.
    • If there is a fan mounted on the side panel, make sure to unplug the cable before fully removing the panel.
  3. Desktop PC Graphics Card Replacement, Graphics Card: stap 3, afbeelding 1 van 1
    • Remove the Phillips #2 head, 5mm screw holding the graphics card in place.
    • Make sure that you have grounded yourself so that upon removal of the graphics card you do not accidentally shock the circuit board and damage it.
  4. Desktop PC Graphics Card Replacement: stap 4, afbeelding 1 van 2 Desktop PC Graphics Card Replacement: stap 4, afbeelding 2 van 2
    • Press the latch on the side of the connector area to unlock the graphics card, and carefully slide the graphics card out from its slot in the computer.
    • A good technique is to lay the computer onto it side, push the latch down and lift the graphics card out.
Conclusie
86 andere personen hebben deze handleiding voltooid.
David Lennon
10.144 Reputatie
10 handleidingen geschreven
Cal Poly, Team 4-5, Maness Spring 2015 Lid van Cal Poly, Team 4-5, Maness Spring 2015
CPSU-MANESS-S15S4G5
4 Leden
45 handleidingen geschreven
3Gids Commentaar
There should be a notice about the PCI-E slot, which has a security latch; the latch should be pressed in order to remove the graphics card from the motherboard.
Onel Jimenez - Antwoord
I have a all in one pc so this is not relevant
Robert Campanelli - Antwoord
any diffrerences in slots?
benzy aceware - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 50
Afgelopen 30 dagen: 171
Altijd: 19,567
