Ga door naar hoofdinhoud
Onderdelen
Geen onderdelen opgegeven.
  1. Minimize exposure to items that can charge up and produce static electricity.
    • Minimize exposure to items that can charge up and produce static electricity.
    • Use an anti-static wrist band.
  2. Power off PC via Windows.
    • Power off PC via Windows.
    • Switch off Power Supply
  3. Put screws where you wont lose them Put screws where you wont lose them
    • Put screws where you wont lose them
  4. Be gentle to not pull with to much force when removing power cables.
    • Be gentle to not pull with to much force when removing power cables.
  5. Try not to touch other components.
    • Try not to touch other components.
    • Gently pull the card out of the slot.
  6. Verify that the notch in the connector matches the motherboard before sliding in.
    • Verify that the notch in the connector matches the motherboard before sliding in.
    • Carefully slide in GPU until you hear a click on the motherboard.
  7. Insert wisdom here.
    • Insert wisdom here.
  8. Use same screws from step 2.
    • Use same screws from step 2.
    • Flip power supply switch back to on.
    • Plug in PC and turn on.
    • If PC does not post go back through the steps to see if you missed something.
    • Go to manufacturer's website or use the CD that came with the card to download the latest drivers for the GPU to ensure better stability of GPU.
    • Enjoy your new GPU.
Conclusie
Joseph Thompson
205 Reputatie
1 Handleiding geschreven
0 Opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 137
