Inleiding
Is the CD drive on your desktop computer not working? Use this guide to replace the malfunctioning CD drive in eight easy steps.
Wat je nodig hebt
Find a large table or flat non-carpeted space to work.
Unplug all external cables, including the power cable, from your computer.
Depending on the case, It may be necessary to remove the top panel in order to get to the CD drive. If you can access the drive without removing the top, skip this step.
On the back of the computer, unscrew the screws connecting the top panel to the case.
Inside the computer, Unscrew the screws connecting the top panel to the case.
Slide the top panel backward and lift it off the case.
28 andere personen hebben deze handleiding voltooid.
2 opmerkingen
موقع سي جدا جدا لا يمكن الاعتماد علية
موقع سي لا يعتمد علية
