Inleiding
Before you begin the RAM replacement process, be sure to ground yourself. Grounding yourself prevents short circuiting the device, and/or shocking yourself. An easy way to do so would be to remove one of your shoes.
Wat je nodig hebt
Remove the two M2x3mm screws from the center panel on the back of computer with a Phillips #0 screwdriver head.
Één andere persoon heeft deze handleiding voltooid.
