Ga door naar hoofdinhoud
Dell XPS M1710 Memory Replacement
    • NOTE: In order to take advantage of the dual channel bandwidth capability, both memory slots must be populated and must match in size
    • Memory modules purchased from Dell are covered under your computer warranty.
    • CAUTION: Before you begin any of the procedures in this section, follow the safety instructions in the Product Information Guide.
    • NOTICE: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on the back of the computer).
    • NOTICE: To avoid damaging the system board, you must remove the battery before you begin working inside the computer.
    • Ground yourself by touching one of the metal connectors on the back of the computer
    • Turn the computer over, loosen the captive screws on the memory module cover, and then remove the cover.
    • NOTICE: To prevent damage to the memory module connector, do not use tools to spread the memory-module securing clips
    • If you are replacing a memory module, remove the existing module:
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the module pops up.
    • Remove the module from the connector
    • NOTE: If the memory module is not installed properly, the computer may not boot properly. No error message indicates this failure.
    • Ground yourself and install the new memory module:
    • Align the notch in the module edge connector with the tab in the connector slot
    • Slide the module firmly into the slot at a 45-degree angle, and rotate the module down until it clicks into place. If you do not feel the click, remove the module and reinstall it.
    • NOTICE: If the cover is difficult to close, remove the module and reinstall it. Forcing the cover to close may damage your computer
    • Replace the memory module cover.
    • Insert the battery into the battery bay, or connect the AC adapter to your computer and an electrical outlet.
    • Turn on the computer.
    • As the computer boots, it detects the additional memory and automatically updates the system configuration information. If prompted, press <F1> to continue.
    • To confirm the amount of memory installed in the computer, click the Start button, click Help and Support, and then click Computer Information.
Conclusie
Amia Frazier
887 Reputatie
7 handleidingen geschreven
RampUP America, Inc. Lid van RampUP America, Inc.
Community
43 Leden
1.985 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 7
Altijd: 53
