Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Turn the computer upside down with the battery facing you.
Push the switch as far to the right as possible to unlock the battery.
Remove the battery using two hands and pull it away from the computer.
Unscrew the four Phillips #1 screws holding down the back panel. Then remove one 5.8mm Phillips #1 screw labeled "M" in the middle of the back panel.
Four 3.9mm Phillips #1 screws
One 5.8mm Phillips #1 screw
Using the highlighted indent, pull up and out to remove the back panel.
Push out on the first set of metal tabs to release and remove the top RAM chip.
Push out on the second set of metal tabs to release and remove the lower RAM chip.
3 andere personen hebben deze handleiding voltooid.
