Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Turn the computer upside down with the battery facing you.
Push the switch as far to the right as possible to unlock the battery.
Remove the battery using two hands and pull it away from the computer.
Unscrew the four Phillips #1 screws holding down the back panel. Then remove one 5.8mm Phillips #1 screw labeled "M" in the middle of the back panel.
Four 3.9mm Phillips #1 screws
One 5.8mm Phillips #1 screw
Using the highlighted indent, pull up and out to remove the back panel.
First, unscrew the six screws that are holding down the fan and heat sink with a Philips #1 screwdriver. Then use a Phillips #1 to remove the single screw near the bottom of the heat sink.
Six Silver Chrome 5.8mm Phillips #1 screws
Carefully lift the fan and heat sink from the laptop.
Use your fingers or a spudger to remove the power pin connecting the fan to the laptop by pulling it straight up off the motherboard.
Één andere persoon heeft deze handleiding voltooid.
