Ga door naar hoofdinhoud
Dell XPS M1530 Heat Sink Replacement
Wat je nodig hebt
  1. Dell XPS M1530 Heat Sink Replacement, Battery: stap 1, afbeelding 1 van 1
    • Turn the computer upside down with the battery facing you.
    • Turn the computer off and disconnect the charging cable from the computer.
    • Failure to unplug the charging cable may result in electric shock.
  2. Dell XPS M1530 Heat Sink Replacement: stap 2, afbeelding 1 van 1
    • Push the switch as far to the right as possible to unlock the battery.
  3. Dell XPS M1530 Heat Sink Replacement: stap 3, afbeelding 1 van 2 Dell XPS M1530 Heat Sink Replacement: stap 3, afbeelding 2 van 2
    • Remove the battery using two hands and pull it away from the computer.
  4. Dell XPS M1530 Heat Sink Replacement, Heat Sink: stap 4, afbeelding 1 van 1
    • Unscrew the four Phillips #1 screws holding down the back panel. Then remove one 5.8mm Phillips #1 screw labeled "M" in the middle of the back panel.
    • Four 3.9mm Phillips #1 screws
    • One 5.8mm Phillips #1 screw
  5. Dell XPS M1530 Heat Sink Replacement: stap 5, afbeelding 1 van 2 Dell XPS M1530 Heat Sink Replacement: stap 5, afbeelding 2 van 2
    • Using the highlighted indent, pull up and out to remove the back panel.
    • The indent should provide enough grip to remove the panel with ease.
  6. Dell XPS M1530 Heat Sink Replacement: stap 6, afbeelding 1 van 2 Dell XPS M1530 Heat Sink Replacement: stap 6, afbeelding 2 van 2
    • First, unscrew the six screws that are holding down the fan and heat sink with a Philips #1 screwdriver. Then use a Phillips #1 to remove the single screw near the bottom of the heat sink.
    • Six Silver Chrome 5.8mm Phillips #1 screws
    • Remove the four screws that are holding down the CPU (the four to the top left that form a rectangle in this image) first. Unscrew them in an X pattern (eg. top left screw, bottom right screw, top right screw, bottom left screw) to minimize risk of harming CPU.
  7. Dell XPS M1530 Heat Sink Replacement: stap 7, afbeelding 1 van 2 Dell XPS M1530 Heat Sink Replacement: stap 7, afbeelding 2 van 2
    • Carefully lift the fan and heat sink from the laptop.
    • Be careful not to pull up too hard, because the power pin is still connecting the fan to the laptop.
  8. Dell XPS M1530 Heat Sink Replacement: stap 8, afbeelding 1 van 1
    • Use your fingers or a spudger to remove the power pin connecting the fan to the laptop by pulling it straight up off the motherboard.
  9. Dell XPS M1530 Heat Sink Replacement: stap 9, afbeelding 1 van 1
    • Remove the fan and heat sink from the laptop.
    • When installing the new heat sink, do not forget to replace the thermal paste underneath the heat sink. See iFixit's Applying Thermal Paste guide for further instructions.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Jase Sasaki
721 Reputatie
5 handleidingen geschreven
Cal Poly, Team 18-4, Maness Winter 2015 Lid van Cal Poly, Team 18-4, Maness Winter 2015
CPSU-MANESS-W15S18G4
4 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 7
Altijd: 964
