Inleiding
This is a last step to fixing your laptop if it refuses to turn on after the battery and power cord are addressed. Additionally, if any problems that have occurred correspond with the troubleshooting page then you should replace the CPU.
Gereedschap
Onderdelen
Geen onderdelen opgegeven.
Unscrew the four Phillips #1 screws holding down the back panel. Then remove one 5.8mm Phillips #1 screw labeled "M" in the middle of the back panel.
Four 3.9mm Phillips #1 screws
One 5.8mm Phillips #1 screw
Use a Metal Spudger to turn the black plastic screw to the unlock position from the secure position of the CPU on the motherboard.
