Inleiding
If your fan needs to be replaced, remove the back panel using this guide. For this guide, you will need a Phillips screwdriver with a PH01 head and tweezers. This process will be relatively easy to follow along, with only a couple steps needing careful focus to prevent damage to the laptop itself.
Wat je nodig hebt
Remove the four 5.0mm screws with a Phillips #1 screwdriver.
Remove the one external 5.0mm screw with a Phillips #1 screwdriver.
Remove the fan cover.
Één andere persoon heeft deze handleiding voltooid.
