Ga door naar hoofdinhoud
Dell XPS M1330 CPU Replacement
Wat je nodig hebt
  1. Dell XPS M1330 CPU Replacement, Battery: stap 1, afbeelding 1 van 1
    • Flip the laptop on its back, so that the underside is facing up.
  2. Dell XPS M1330 CPU Replacement: stap 2, afbeelding 1 van 1
    • Push and hold the slide button to the left and unlock the mechanism.
  3. Dell XPS M1330 CPU Replacement: stap 3, afbeelding 1 van 2 Dell XPS M1330 CPU Replacement: stap 3, afbeelding 2 van 2
    • Lift the computer up and slowly pull the battery straight out from the device.
  4. Dell XPS M1330 CPU Replacement, Fan: stap 4, afbeelding 1 van 2 Dell XPS M1330 CPU Replacement, Fan: stap 4, afbeelding 2 van 2
    • Remove the four 5.0mm screws with a Phillips #1 screwdriver.
    • Remove the one external 5.0mm screw with a Phillips #1 screwdriver.
    • Remove the fan cover.
  5. Dell XPS M1330 CPU Replacement: stap 5, afbeelding 1 van 1
    • Remove the four 0.1mm screws using the Phillips #1 screwdriver.
    • Remove the one thicker 0.1 mm screw using the Phillips #1 screwdriver.
  6. Dell XPS M1330 CPU Replacement: stap 6, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Koop
    • Be sure to carefully remove the wires as they are fragile and can rip easily.
    • Remove the wire bay near the fan.
    • Use the long nosed tweezers to carefully handle the white plastic piece that holds the wires together.
    • Gently pull upward while moving your hand side to side so the plastic holder will detach.
  7. Dell XPS M1330 CPU Replacement: stap 7, afbeelding 1 van 1
    • Gently remove the fan and its attachments from the bay.
  8. Dell XPS M1330 CPU Replacement, CPU: stap 8, afbeelding 1 van 1
    • Using the flathead screwdriver, turn the one screw counterclockwise to loosen the CPU, but do not remove the screw.
  9. Dell XPS M1330 CPU Replacement: stap 9, afbeelding 1 van 1
    • Using the iFixit opening tool, prop up the CPU.
  10. Dell XPS M1330 CPU Replacement: stap 10, afbeelding 1 van 1
    • Carefully lift the CPU away from its housing.
Conclusie
Kai Kapossy
676 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team S6-G2, Peak Spring 2019 Lid van UMass Dartmouth, Team S6-G2, Peak Spring 2019
UMASSD-PEAK-S19S6G2
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 12
Altijd: 645
